It is currently Wed Aug 20, 2025 6:48 pm
 Post subject: unheated side bender
PostPosted: Wed Feb 26, 2014 5:37 pm
First name: herry
Last Name: trismono
City: malang
State: east java
Zip/Postal Code: 65142
Country: Indonesia
Hi, I'm coming with 1 question:
whether side bending can be done without heating blanket? that mean I will steam or boil the side wood and then put on the side bending mold, press it and leave it maybe couple days until dry.
Can it work? duh
thank's so much, herry
 Post subject: Re: unheated side bender
PostPosted: Wed Feb 26, 2014 6:01 pm
you might try 3 150 watt light bulbs in your side bender.... not as even heating as a blanket but it will work
These users thanked the author jack for the post: herry tze (Wed Feb 26, 2014 6:51 pm)
PostPosted: Wed Feb 26, 2014 6:14 pm
I think I saw a book for classical guitars which told how to soak the sides and bend them on an inside mold and let them dry. There was a lot of spring back, but the sides could still be forced subsequently into and outside mold. After assembly, all the joints worked together to prevent the sides from springing back. I am not recommending this, and I sure would not try it with expensive wood. More recently, people are using Super Soft 2 to make bending easier with heat, so I suppose it would also help without heat. The above mentioned light bulbs are reported by many to work very well.
These users thanked the author wbergman for the post: herry tze (Wed Feb 26, 2014 6:52 pm)
PostPosted: Wed Feb 26, 2014 6:16 pm
Boiling sides. That's how Mr. Sloane did his, hence how I did my very first Guitar sides. It does work but the sides are prone to cupping/corrugating and spring back. I don't know of anyone who still uses the method. That might tell you something.
If you try it you might need more than a couple of days for it to dry out.
These users thanked the author Michael.N. for the post: herry tze (Wed Feb 26, 2014 6:52 pm)
PostPosted: Wed Feb 26, 2014 6:20 pm
Sorry to tell you but it takes heat. Steam will cause undo warping. I will not recommend light bulbs as I know of a few shops that burnt down from them so NEVER LEAVE A BENDER UNATTENDED .
You can bend by hand but if you are going to invest 100 hr to make a guitar. I bet someone live near you and can help.
These users thanked the author bluescreek for the post: herry tze (Wed Feb 26, 2014 6:52 pm)
PostPosted: Wed Feb 26, 2014 6:24 pm
Many years ago I did my first guitar following the Sloane book. That involved boiling the sides in a trough and clamping them to a form for a week while they dried. It worked, but not the method I would recommend these days.
I have also bent several sets of sides using light bulbs in a form. It does work, but the challenge is the air gap at the waist area. For the same reason, I would not recommend trying a cutaway side with a form heated by light bulbs.
Things got much easier when I got a heat blanket and this is what I would recommend even though this is not what you asked or probably wanted to hear.
These users thanked the author Pat Hawley for the post: herry tze (Wed Feb 26, 2014 6:52 pm)
PostPosted: Wed Feb 26, 2014 6:33 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
You can use an old clothes iron, I use one in conjunction with light bulbs.
Scroll down to the middle of page 2:
viewtopic.php?f=10133&t=37283&start=25
I believe you could get away without the bulbs and just use the iron.
These users thanked the author Rodger Knox for the post: herry tze (Wed Feb 26, 2014 6:52 pm)
PostPosted: Wed Feb 26, 2014 6:56 pm
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
thank you so much all seniors, first I'll try with light bulb thank's Jack, because it's cheap and easy installing for me, and John F Hall, I've saw your youtube thank's that's bless me, thank's again all of you
PostPosted: Wed Feb 26, 2014 6:57 pm
I once used the method of cold bending on the recurve of an archery bow. We made a former and spritzed the wood (4 mm !! Ash ) and very, very slowly cranked the wood around. It has to be done slowly to allow the wood fibres to stretch and become accustomed to their new position. It worked. Fair degree of springback but we had allowed for that.
I think for Torres style ribs and extremely well behaved wood . . . it just might work. You would probably have to glue the linings on whilst it's still in the mould. Eat Drink
Then again. . . get yourself some hot fire and a metal pipe. :?
PostPosted: Thu Feb 27, 2014 12:16 am
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
I've bent air-dried Ash 2mm minimum thickness, might have been a nit more, without heat. I dampened the wood, wrapped it in foil, left it to sit for an hour or three, then unwrapped it and bent it to the mold. I've even done cutaways this way! I was afraid that one would fail, but no. I clamped some cross grain cauls across the sides and left it to dry for about a week. The wood was dry before this time, but I wasn't. No spring-back.
I don't expect every wood to behave like this, some experimenting would be in order if you want to risk it.
http://redrivercanoe.ca/
PostPosted: Thu Feb 27, 2014 3:22 am
The odd Violin makers uses the cold bend method. It can work for their narrow, very thin ribs. Even in flame Maple. I think I tried Maple once but the rib cracked along the flame.
I've used the method a number of times for bending Ebony Veneer, to go around the back of the Neck. Also a test piece to see if I could do the double bent ribs of the Chambure Vihuela. It does work but a wider range of woods might show it's limitations. I suspect that Ash is one of the easier woods to bend, at least it has a reputation for steam bending etc.
PostPosted: Thu Feb 27, 2014 5:05 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
Bending wood on a hot piece of metal is a skill that is (perhaps) exclusive to lutherie. Why not learn how to do it? Is there some special reason you don't want to do it?
We are all in the gutter but some of us are looking at guitars.
These users thanked the author Joe Sallis for the post: Haans (Thu Feb 27, 2014 6:59 am)
PostPosted: Thu Feb 27, 2014 5:40 am
You could use the same argument for heating blankets and bending machines though. It requires knowledge but essentially it's the jig that does the skilled bit. The only difference is that he wants to use steam or boiling water as the means to make the wood fibres pliable.
PostPosted: Thu Feb 27, 2014 8:19 am
First name: joseph
Last Name: sallis
Country: UK
I'm not getting into an argument about one being better than the other.
I just had some moments of romanticism about the beauty of the craft; coaxing the wood into pliability and the moment of release when the wood relaxes into shape.
One thing though, the hot iron is more useful for little jobs- binding around headstock for example.
PostPosted: Thu Feb 27, 2014 8:42 am
Online
Pat Hawley wrote:
....................It does work, but the challenge is the air gap at the waist area. For the same reason, I would not recommend trying a cutaway side with a form heated by light bulbs.
I've bend several with light bulbs too, but I filled the "air gap at the waist" during the initial heating with a small sheet of aluminium foil each side.
Helps to retain the hot air, and folds to almost nothing (or can be quickly removed after you are up to temperature) as you bend the waist.
Not saying a heating blanket isn't better, but some people don't have the budget for one.
PostPosted: Thu Feb 27, 2014 9:39 am
I found room in my budget for a heating blanket after I broke a macassar ebony side trying to do a cutaway on a light bulb heated bending form. Funny how trashing some expensive wood can change your budget priorities.
If your intention is to build more than one or two guitars or a cutaway guitar, I highly recommend that you bite the bullet now and get a heating blanket. I would also recommend spring steel slats to go with that heating blanket. I'm a big believer in the spring steel which provides some support to both sides of the wood as it bends.
PostPosted: Thu Feb 27, 2014 11:41 am
Not to highjack, but a question, if I may?
I see the heating blankets sold with temperature controls and other hardware/equipment, and those pieces cost even more in some cases than the blanket itself. And all of the vendors say don't use the blanket without their high dollar temperature control.
Can the blankets be used without these as long as a person uses a bit of common sense?
PostPosted: Thu Feb 27, 2014 12:32 pm
I would say "yes" to that Mike provided that you use a thermometer and keep a close watch on the temperature. I use a router speed control but as often as not, have my sides bent prior to switching the control from "full power" to "variable". I start bending waist and lower bout at around 240 F and by the time I'm doing the upper bout I'm at around 300 F which seems to work out well. So it could all be done without the controller. That being said, I've found the router speed control a handy thing that can be used for more than just bending sides - for example controlling the speed of a router.
Cheers,
PostPosted: Thu Feb 27, 2014 12:38 pm
First name: Larry
Last Name: Hawes
I imagine it could be done with a bit of common sense but I also I think it depends a little on the blanket as they come in various wattages. I have a higher watt model and it gets very hot VERY fast. Without a controller of some kind it would be really hard to turn it on and off manually and have much success. And a good quick response thermometer is a must for my uses as well.
I used that router speed controller from Harbor Freight for a while, before building a more sophisticated system, and it worked great. Cheap insurance against over heating IMO.
Thank You and Best To All
PostPosted: Thu Feb 27, 2014 1:11 pm
Thanks, Pat and Larry!
PostPosted: Thu Feb 27, 2014 1:38 pm
First name: Greg
Last Name: B
City: Los Angeles
Can it work?
Well, yeah, it can be done. Like some of the other posters, I bent my first few sides according to the instructions in Sloane's books, and steamed a couple sets too. If you really want to boil/steam, there will be some springback, and you'll need to use a mold. It will do the job OK, but the wood has a tendency to cup and warp. You'll end up spending much more time with a scraper trying to even it out than if you bend it on a hot pipe. When you bend on a pipe, it tends to sort of iron the sides flat (across the width), so overall it is much easier and gets better results.
PostPosted: Thu Feb 27, 2014 10:58 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
viewforum.php?f=10101
MK5acoustics.com
PostPosted: Thu Feb 27, 2014 10:59 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
MK5acoustics.com
PostPosted: Thu Feb 27, 2014 11:00 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
ops lets try this Eat Drink
MK5acoustics.com
PostPosted: Fri Feb 28, 2014 6:54 pm
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
Hi Joe, thank's, I've tried and did the first time for hot pipe, and I am quite happy to do this job, but after seeing the tool with models bending machine + heating blanket I see that with this tool more perfect result.
My first difficulty is heating blanket is too expensive for me, second; for hot pipe I've tried heating system with charcoal lighter but I did not heat stable, so I'm burning on the stove, because I burn quickly cool air over and over and it's boring for me. In a few days I will upload photos of the guitar side bending results of my first, I was preparing the photograph.
thank you all the best advice
herry
Users browsing this forum: Colin North, Ken Lewis and 15 guests
